Shortest Code to change styles of all drawing views in NX using vb/journal
DeerSpotter
Military
Apr 27, 2022
let me know if there is a better way, this is my first post here on eng-tips
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim startSheet As Drawings.DrawingSheet = theSession.Parts.Work.DrawingSheets.CurrentDrawingSheet
Dim views As ModelingViewCollection = workPart.ModelingViews
'iterate through the view collection
For Each vw As NXOpen.Drawings.DraftingView In startSheet.SheetDraftingViews
Dim editViewSettingsBuilder1 As NXOpen.Drawings.EditViewSettingsBuilder = Nothing
editViewSettingsBuilder1 = workPart.SettingsManager.CreateDrawingEditViewSettingsBuilder({vw})
Dim editsettingsbuilders1(0) As NXOpen.Drafting.BaseEditSettingsBuilder
editsettingsbuilders1(0) = editViewSettingsBuilder1
workPart.SettingsManager.ProcessForMultipleObjectsSettings(editsettingsbuilders1)
'change all view settings here use editViewSettingsBuilder1.yourcodehere
editViewSettingsBuilder1.ViewStyle.ViewStyleSmoothEdges.SmoothEdge = True
editViewSettingsBuilder1.ViewStyle.ViewStyleSmoothEdges.Color = workPart.Colors.Find("Light Gray")
editViewSettingsBuilder1.ViewStyle.ViewStyleSmoothEdges.Font = NXOpen.Preferences.Font.Phantom
editViewSettingsBuilder1.Commit()
next
End Sub
End Module
The .CreateDrawingEditViewSettingsBuilder accepts an array of views as the input. I've not tried it, but you can probably pass them all in at once and avoid the for loop.
Code:
editViewSettingsBuilder1 = workPart.SettingsManager.CreateDrawingEditViewSettingsBuilder(startSheet.SheetDraftingViews.ToArray())
Whether you use the for loop or pass them all in at once, you will need to call the .Destroy method right after the .Commit. Builder objects that are not destroyed can later cause strange behavior in NX.
Code:
editViewSettingsBuilder1.Destroy()
www.nxjournaling.com
