Show a list of which colors a part is using.
JurgenKreisel
Automotive
CA
Good morning.
Does anyone know of a way to get a list of what colors a part is using.
We have a color map that the designers use. They are only supposed to use the 60 favorite colors but sometimes the rules are not followed.
Is there a way to interrogate a part and get a list of what colors that part uses. This way it is easy to see if the rules were not followed.
I know that I can select every surface and do an information query but if a part has several thousand surfaces the list is extremely long and almost impossible to use.
Ideally just a summary of colors used and nothing else.
Currently using NX11 and NX12 on windows 7 and 10.
Jurgen
I don't think there is any built-in function to do this. But it would be about a dozen lines of code using the SNAP or NX/Open APIs. Ask again if that's an option that interests you.
Try this code:
Code:
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Module Colorface
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
	Dim List1 As New List(Of String)
        For Each theBody As Body In workPart.Bodies
            Dim bodyFaces() As Face
            bodyFaces = theBody.GetFaces
		For Each tempFace As Face In bodyFaces
			if not List1.contains(tempface.color) then
				List1.Add(tempFace.color)
			end if
            	Next
        Next
	if Not IsNothing(List1) AndAlso List1.Count > 0 Then
		List1.sort()
		lw.writeline(" ")
		lw.writeline("********************")
		lw.writeline("COLORS USED IN PART:")
		lw.writeline(" ")
		for each facecolor as string in List1
			lw.writeline(facecolor)
		next
	end if
   End Sub
End Module
With best regards
Michael
Thank you for the program.
Actually we created a program within excel to give a report.
Select all faces and do an info report. Copy the entire report into excel and run the program.
Just comes back with a list of colors used within the entire part, it actually shows the little color box that info gives you from within NX.
