What are the best practices for constructing sill plate anchor bolts along the edge of a slab on grade with monolithic footing (i.e., not a stem wall foundation)? Is the best practice to cast these bolts using a manufacturer's anchor? Post install these with epoxy anchors? What is the typical bolt diameter. I got 1/2" minimum from the applicable building Code. I wasn't sure if 5/8" is more common.
I'm using a 2x6 wall, and anticipate setting the bolts 2 3/4" from the edge of concrete. I would like to use one of the product shown below, but their slab edge details account for an additional "ledge" built into the foundation. Where I'm located, we typically use the footing shape shown below.
Simpson "SB" anchor bolt that I'd like to use:
Edge distance detailing for this anchor bolt. Note the additional ledge with providing (1.75" + 1.5") 3.25" cover from the bolt centerline:
Intended footing shape. Ignore the anchor bolt type (refer to question above):
