Silly question: PLF to PSF
gmoney731
32
This is an embarrassing and silly question for a structural engineer to ask.
Let's say I have an L2x2x1/4, with a weight of 3.19 PLF (from AISC) and an area of 0.944 in^2 (0.0065 ft^2). It is 5' long.
I want to calculate a PSF load associated with that angle...how would I go about getting that answer.
I understand that AISC takes 490 PCF x A_angle = 3.19 PLF, and that times 5' can give me ~16 LBS as the weight...but what is the PSF equivalent of this?
Thanks for your time.
You would take that PLF load and divide it by the spacing of the angles.
jayrod12 is correct. If you are having trouble visualizing this, imagine taking the 3.19 pounds for a one foot length of angle, and "smearing" it half the angle spacing in each direction.
DaveAtkins
Can you explain this more? I was going to take the 3.19 PLF, multiply it by the length of the angle to get a LBS value, multiply that by the number of angles, and then divide that by the tributary area (plan view) of the joist?
That is the same calculation, just more steps.
Let's say you have 5 ft long angles at 3.2 PLF and you have them spaced at 4ft on-centre. You could go 3.2PLF*5ft*2=32 lbs and divide that by the total area = 2*5ft*4ft=40 square feet equaling 0.8 PSF (assuming we just look at two angles, scale up for as many as you have). Or take 3.2PLF divided by 4ft = 0.8 PSF. The same number with less steps and less chance for error. And can be applied universally regardless of length and width of area.
It is indeed a silly question. PLF cannot be converted to PSF no matter how hard you try. They are simply different units.
BA
