Hi there,
We tried to make a simple plate 300 micron thick sheet using two prepreg layers (SIGRAPREG® C W205-TW2/2-E323/43%). They were pressed with two aluminium plates (15mm thick) and 8 M16 screws. They are 50x40cm2 (20x15 inches2)
The result was insatisfactory. There is a middle strip without resin. It has an interesing pattern: it expands on the ends.
Also, on the "good section" there are small imperfections. There is not a nice glossy surface.
Why is this happenning? too tight? too loose?
Down here some pictures
thanks
regards,
thanks
regards,
