brandnew1
Aerospace
- Apr 9, 2010
- 73
i believe this to be a silly question but i'm no expert and thus i just want to verify if this is the same or valid interpretation.
There is a true position callout with a M modifier to datum A. i've always interpreted this where the feature (square slot) needs to be 'centered' to Datum A no more than .001 out of position. If this was a diameter i would add "Bonus tolerance" if the diameter moved away from maximum material.
The Question: This being a square slot, does bonus apply here if the dimension is greater than .252?
The more difficult question: Is there a basic rule that indicates when looking at FCF's, its very "clear" that it is a datum shift allowance versus "bonus"? (what i mean by this, if i see the circle M on a datum in the FCF this is a shift, but if the M is inside the tolerance this is something else?
thank you
thank you
