Am working on simulation of the moving heat source of double ellisopidal heat source model (In ansys ACT extension Gaussian moving heat source is only available)..To find out the temperature distribution along the weldzone. Giving convection and moving heat source (UDF) as input. In the code the mathemtical equation of double ellipsoidal is given. But am not getting the temperature distribution reference to the double ellipsoidal graph.
Error with temperature profile in the ouput. Can any one help me. please.
Code is attached. Can you please check the code..
CMSEL,ALL
*GET,EMAX,ELEM,,NUM,MAX
*GET,EMIN,ELEM,,NUM,MIN
ALLSEL
AUTOTS,ON
TIME_WELD=100
DT=1 ! Time step
A=0.003
B=0.004
C1=0.004
C2=0.016 !A, B AND C ARE JUST THE HEAT SOURCE DIMENSIONS
TAU=0 !TIME DELAY
FF=0.6 !FRACTION OF HEAT ON THE FRONT PART OF THE HEAT SOURCE
FR=1.4 !FRACTION OF HEAT ON THE REAR PART OF THE HEAT SOURCE
Q=3840 !WELDING ENERGY J/S (W)
VEL=1.73e-3 !WELDING SPEED
!!EE=2.71 !I HAD TO DEFINE THE EULER NUMBER AS 2.71 INSTEAD OF USING exp() DUE TO UNSTABILITIES ON MY RESULTS
NPT=TIME_WELD/DT
NROPT, FULL
*DO,i,1,NPT,1 !TIME INCREMENT
WTIME=(i/2)
TIME,WTIME
HCENTER=VEL*WTIME !HEAT SOURCE CENTER
*DO,jj,EMIN,EMAX,1 !SELECTS THE CENTROID OF EVERY ELEMENT
X=CENTRX(jj)
Y=CENTRY(jj)
Z=CENTRZ(jj)
CSI=Z+(VEL*(TAU-WTIME)) !MOVING COORDINATE (IT MOVES THROUGH Z AS TIME PASSES
*IF,Z,GT,HCENTER,THEN !DEFINES WHETHER IT'S THE FRONT PART OF THE HEAT SOURCE OR THE REAR PART
C=C1
F=FF
*ELSE
C=C2
F=FR
*ENDIF
PART1=(6*(3**0.5)*Q*F)/(A*B*C*3.14*(3.14**0.5))
PART2=(Exp(-3*(X/A)**2))*(Exp(-3*(Y/B)**2))*(Exp(-3*((CSI/C)**2)))
QF=PART1*PART2 !HEAT SOURCE EQUATION
BFE,jj,HGEN,,QF
*ENDDO
SOLVE
*ENDDO
CMSEL,ALL
BFEDELE,ALL,ALL
ALLSEL
CMSEL,ALL
ALLSEL
AUTOTS,ON
TIME_WELD=100
DT=1 ! Time step
A=0.003
B=0.004
C1=0.004
TAU=0 !TIME DELAY
NPT=TIME_WELD/DT
NROPT, FULL
WTIME=(i/2)
TIME,WTIME
X=CENTRX(jj)
Y=CENTRY(jj)
Z=CENTRZ(jj)
C=C1
F=FF
*ELSE
C=C2
F=FR
*ENDIF
BFE,jj,HGEN,,QF
*ENDDO
SOLVE
*ENDDO
CMSEL,ALL
BFEDELE,ALL,ALL
ALLSEL
