Single Point Failure Modes
Mbrooke
2,546
Am I the only who sees videos like this and thinks that the owners got screwed/duped?
If the bus coupler breaker fails, a breaker sticks or the gear software fails the whole facility is left without power.
You are not the only one.
The most common single point of failure is the battery/ control power.
If they had used different switchgear for the two buses, there would be a tie breaker on each gear. This was a cost saving choice to use a single gear lineup.
Many plants also don't have but one relay per feeder.
On the other hand it is possible to go overboard with too many systems of backup, making a complicated mess.
I agree with both of your replies. Its seems like reliability theory no longer holds or is thought about.
Not saying it’s perfect but your could look to offshore dynamic positioning vessels to see how / how not to design when operating a closed bus system. More savvy vessel owners will demand verification of things like short circuit testing of main bus, simulated failures etc. each year vessels in service are required to go through failure mode simulations that prove the redundancy concept and the ability of the ship to keep position in the water during the worst case failure
DP3 systems are designed for failures in all parts of design including flooding of compartment the routing of cables, etc etc
There is the question of what is the cost of fixing the problem.
For power plants, there are so many things that can go wrong, that it is better to have more than one power plant.
