kdv1988
- Aug 13, 2019
- 66
I am interested in knowing if a single-step wastewater clarifier/reclaimer can be made for used Parts Washer effluent. References can be found here :-
1. 2.
Both these products use a Clay based Flocculant/Coagulant. Now I have done some research here in India and spoke to a bunch of manufacturers who have no experience with such Flocculants. I then spoke to a company in the US who have sent me some samples as per their experience of similar applications.
Link -
The equipment we would like to design will include a Treatment tank with a Mechanical stirrer. The effluent will be fed into the tank where the flocculant is added and then stirred. After flocculation is complete, the liquid is passed through a Filter Paper Bed and collected in a collection tank underneath.
This water can then be sent through some post-filtration to remove odor/color (would like your suggestion for this) and then re-used in the same machine / different process / gardening etc.
The industry standard procedure right now is to drain the effluents from each machine into a reservoir which later goes through an Effluent Treatment Plant (ETP) and then drained/re-used. An ETP is a huge capital expenditure, and that is where we're hopeful of providing a low-cost alternative provided this can actually replace an ETP.
I have not done any Lab Tests of the effluents as the effluents will keep varying with every machine/customer.
Any guidance / help would be appreciated. Thanks.
1. 2.
Link -
