superdeepsix
Chemical
- Jul 20, 2004
- 13
To all structural engineers:
Can you sister an existing joist using smaller dimensional lumber?
For instance I have a 12 ft span with 2x10s Douglas Fir spaced 16". O.C. I want to add 2x8 Douglas Fir sisters across entire span, to each bearing point(mudsill to center I beam), as I can easily thread 2x8s into the joist bays without removing a ton of electrical and plumbing. Note I can only sister one side of 2x10 as the joists across the floors overlap one another on the center I beam.
If you are able to sister using smaller dimensional lumber, does the member attach at the bottom or top of existing joist? I assume bottom as that part of joist is in Tension and the wood is more suspectible to cracking due to the bending stress applied by the floor above.
And lastly 16d nails, carriage bolts, screws, or a combination of two?
