SteelPE
- Mar 9, 2006
- 2,759
I was recently called out to look at an issue a client found while renovating an old 1800’s era brownstone. During demolition of the existing partitions, the client hit an old column that appears to be holding up a header beam ( 5 ¼” x 11”) that frames around an old fireplace. This column ends up right in the location that they want to put their bathroom vanity. Simple solution, adjust the bathroom layout around the discovered column….. not with these clients, they want this vanity as designed no questions asked and the column must go.
I am not exactly sure why the column is there in the first place. It is obviously there to support the header beam which is 21” short of the existing bearing wall. Why didn’t they bear the beam on the wall to begin with….. I have no idea.
I am toying around with the idea of extending existing wood header the 21” to bear on the existing brick bearing wall by sistering steel channels (maybe some 8’ long 10” deep channels that overlap the existing wood beam a good 5’-0”-6'-0") that would be through bolted through the 5 ¼” x 11” wood beam. I am not exactly sure about the magnitude of the load we are dealing with…. But I am thinking we need to support about 3,000 lbs.
Does this solution seem feasible and are there any drawbacks?
