My facility is putting in a new piece of equipment, and I need to determine the size of the service line to it. I know the heater input rating, and thus know the CFH the equipment will use. I have seen tables that show the maximum capacity (in CFH) of gas pipe for various diameters and lengths of pipe. However, a lot of these tables note that the capacity is at low gas pressures - 0.5psig or less. Do these pipe capacities change when the system operates at a higher pressure?
I'm a bit lost on what other information I need to make this decision.
Thank you
Thank you
