I liked the NASA simulator program from Zapster's link. For 600 mph, I got an ambient air T = -69oF and a 'total' temperature of -5oF.
The stagnation, or total, temperature "is the temperature of the airflow at a stagnation point, such as the leading edge of the wing or nose of the aircraft." But, I'm still uncertain of the remaining skin temperatures.
So, aero guys, is this 'total' temperature the maximum skin temperature on the aircraft? Does a skin temperature continuum between -69oF and -5oF exist for this aircraft depending upon surface flow?
There should be less heating due to air friction at a stagnation point. Some heat is generated by turbulence within the air. But, of course, also less convective cooling.
Answers?
