Is it permissible to use structural grade material for skirts for ASME VIII Div.1 equipment?
Quoting UG-4(b) Material for nonpressure parts, such as skirts, supports,
baffles, lugs, clips, and extended heat transfer surfaces,
need not conform to the specifications for the
material to which they are attached or to a material specification
permitted in this Division, but if attached to the
vessel by welding shall be of weldable quality [see
UW-5(b)]. The allowable stress values for material not
identified in accordance with UG-93 shall not exceed 80%
of the maximum allowable stress value permitted for similar
material in Subsection C.
The above suggest that non-ASME II material is permitted.
I am unsure exactly how one arrives at a "similar" material?
Our inspector is questioning the fact that structural grade materials which are not in ASME II do not have any published strength data beyond room temperature and hence are not acceptable materials.
Michael
Michael
