Cobra17
- Jun 18, 2020
- 165
I'm looking for a valid way to verify 'Seismic Clip'. The clips are pieces of angle welded to a skirt and bolted to the ground. The skirt on it's own is enough for seismic conditions and I'm thinking that if I do procedure 4-15 from the 4th edition of the Pressure Vessel Design Manual (Moss), which is based on the centered neutral axis method, that I can prove the bolting, base plate thickness and skirt, then a weld shear check for the skirt to lug. I would use the shear and bending moment that I get from running seismic calcs (Compress) on the skirt.
