Nayan67
- Feb 8, 2023
- 32
Hello everyone,
I am currently designing a non-composite steel box girder. Since the system is non-composite, I assumed that the entire bending moment would be resisted by the steel girder alone. During the slab design, I did not consider any longitudinal bending stress in the deck slab and provided only nominal reinforcement. My understanding was that, in the absence of shear connectors, there is no stress transfer between the deck slab and the girder. While there may be local stress in the slab, the overall stress is resisted by the box girder alone. Therefore, the slab does not need to resist longitudinal bending stresses, except for providing nominal reinforcement to address temperature, shrinkage, or other local effects. However, the reviewer has asked that I design the slab for longitudinal bending moments as well. Would anyone be able to recommend a good reference or guideline that discusses slab design for non-composite steel girders?
