Hi guys,
I designed a slab on ground with uniform loads + linear loads on it on SAP2000 and I found the results intriging.
uniform load: self load, SDL=1 kPa, LL=1.9kPa.
line load on the perimeter (factored): 42kN/m
line load on the red zone (check picture)(factored):26kN/m
soil subgrade modulus(k): 9000kN/m^3
250mm thick.
I locked the corners in the xy direction
Im confused with the negative moment under the line load, do you know what happen here, I would have expected a positive moment everywhere
The results are in Knm/m
250mm thick.
