pelelo
Geotechnical
- Aug 10, 2009
- 357
Engineers,
I have a confusion in terminologies, please help.
I have a structure which will be supported on a mat foundation. The mat is 3 ft thick and will be built 3 feet below ground surface (not at grade).
My question is: is this considered truly a mat foundation or a slab on grade?. I think there are confusions about both terminologies.
In case it helps, the loads on the mat foundation will be 300 tons and it has a dimension of 25 x 15 ft.
Please advise. Thanks.
