STrctPono
- Jan 9, 2020
- 706
I was going to transition the floor type on the bottom level from slab on grade to wood joists over a crawl space. The house is built on a very steeply graded lot and it just works out that this makes sense to me as this would save the homeowner on excavation work (existing ground is rock). I'm not sure if there are other issues I'm not considering. There is nothing I don't think I can work around but a few things off the top of my head...
1. The transition from slab-on-grade to floor joists will cut right through both the interior and exterior stud walls. Not sure if it is acceptable to just run the bottom 2x plate right across the joint.
2. The homeowners are using a floating wood floor so I don't think there will be any issues for having to joint the flooring at this transition location.
3. Anything else I am not considering?
I've always appreciated the help I've gotten here in the past regarding home design. Residential design is not my area of expertise, but every once in awhile I do end up helping out on a job.
