Rick A
- Nov 5, 2022
- 4
Hi all,
New guy seeking advice. I have a small Gresen pump out of a bearing press running a 3" x 12" ram and I understood I could slow the ram speed by plumbing in a valve after the pump to modulate oil flow. It doesn't change the speed until just before I close it and then it stops the pump motor. There's no relief valve on the pump that I can see.
Any suggestions? Thank you.
Rick A
Rick A
