mechengineer
Hi Dear All,
I am confused that UG-36(c)(-a)does not give the restriction of r/R. It only limits the size of the hole (r).
I think the basis of UG-36(c)(-a) to exempt from UG-37 opening reinforcement calculation is that even if the peak stress exceeds the yield stress at the small hole, it will still be far away from the yield strength of the entire shell.
For example, if shell ID=248 mm and opening size = 60 mm, assume shell thickness > 10 mm)], the rario of r/R=0.24. I think it should not be considered as a small opening to exempt from UG-37. Where is wrong in my thinking?
Thanks.
Thanks.
