itsmoked
- Feb 18, 2005
- 19,114
YouSlube Turbine vid
This is surprising to me as I've always seen the turbine at the very last millimeter of the penstock. Is this a normal install? Is nothing (major) being lost in translation here or should the turbine actually be at the end?
I'm trying to equate the 500 watts being generated with 'could you pump that much water from the after bay back up to the reservoir with that same 500W'? Seems like you'd need more than a horsepower to move that much making me think there's a huge efficiency hit going on. ??
Keith Cress
kcress -
Keith Cress
kcress -
