Smiley Faces...
Beggar
715
I'm sure this has been addressed before but the search function has been offline this morning and I'm sure someone can provide a quick answer.
My Express Tools seemed to install normally on ACAD 2002. I set up a custom toolbar and turned the rest off. Later, when running ACAD again, all the Express Tools icons have become sunglasses smiley faces.
Why does this happen and how can I get my normal icons back?
Bring back the HP-15
make a new custom toolbar
after selecting "new" in the customize dialog,
select "express" for "save toolbar in menu group"
then re-make you custom toolbar.
icons should remain the same now.
hope this helps
Intel P4 3.0 GHZ
512 DDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
Thanks, Ozzy.
It didn't help, though. All of the ET tools show the smiley icons, even the native ET toolbars.
They used to be there but are gone...
OK, problem solved. Here's what I found on
AutoCAD performs a recompilation on a new or updated MNS menu file to save the compiled resources (icons) in a .MNR file. At the compilation time the required bitmaps (.BMPs, .DLL) should be available. Make sure your bitmaps are available (in the support path) and recompile your menu (e.g. by deleting .MNR and .MNC and restarting AutoCAD, in higher versions by the MENU command and choosing the .MNU file). Can also appear when changing graphic driver color resolution.
