We have a condition where a new parapet will be tall enough to create a snow drift on an existing roof, which is framed with steel bar joists. REinforcing the joists is not desired because of piping running through the joists. We could design a rooftop platform to relieve the snow drift, but we are considering another approach.
Rather than build platform using wide flange beams, it has been suggested that we could install some light-gauge steel framing on the roof which would take the shape of the drift, and thererfore prevent the drift from forming. In other words, the drift is 5.7' high and 22.8' long, and we could build sloped framing that is 5.7' above the top of the roof against the parapet, and then dies into the roof 22.8' back into the building.
This would be like constructing a low slope gable that dies into the flat roof. In thread 507-126797, the poster indicates that a Professor from RPI is of the opinion that for a flat gable, probably no windward drift would form.
What we are considering is building a flat light-gauge steel gable that attaches to the new parapet about 8" below top of parapet. We then come back at an angle of about 10 degrees until we die into the existing flat roof, making sure that our new gable extends beyond the theoretical drift and that our angle is flatter than the theoretical angle. I think this eliminates a surface for a snow drift to form against. This will affect the way the roof drains, but that is being re-worked anyway.
What do you think?
What do you think?
