puszka
- Jul 12, 2022
- 30
Hi, fresh EIT here. I'm working on a few projects with complicated intersecting roofs and building volumes with exterior decks/roof decks and I am slightly confused about how in-depth the snow load analysis is needed for buildings which meet Part 9 in the code.
OBC 9.4.2 indicates the minimum uniform snow load required, and specifies that this is also to be used on exterior platforms and decks. My projects are small-to-large private homes for wealthy clients, and based on the geometry I can see how the snow loads could accumulate through drifting and sliding in a variety of ways. So many at times that it is a bit daunting.
Is 9.4.2 saying that the more complex analyses of part 4 (full sliding/drifting consideration) aren't required in favour of the simplified analysis where the uniform snow load is applied across the projects? Appendix A-9.4.2 even says: "The simplifies specified snow loads are also not designed to take into account roof configurations that seriously exacerbate snow accumulation. This does not pertain to typical projections above a sloped roof, such as dormers, nor does it pertain to buildings with higher and lower roofs. Although two-level roofs generally lead to drift loading, smaller light-frame buildings constructed according to Part 9 have not failed under these loads. Consequently, the simplified calculation may be used in these cases."
Now -- taking the common cases that I work with where there is a combination of (mostly) stick frame and some steel elements (portal frame around large window walls generally), I am understanding that I can apply the simplified uniform load across the roofs/exterior area and do away with the more complicated analyses of Part 4.
Based on everyone's experience, is this a reasonable interpretation?
