chemEcaleb
Chemical
A 450 mm pusher centrifuge operating at 900 rpm discharges 8 tons per hour of 2% wt moisture sodium chlorate into an 10' long 8" vertical cylindrical chute that feeds a fluidized bed dryer (FBD). Chunks of product form on the screen of the FBD directly underneath the feed chute. Efforts have been made to reduce the chunk issue by increasing the height of the bed, increasing airflow, and utilizing a variety of devices (mainly consisting of SS plate at various angles and geometry) lowered in to the dryer underneath the feed chute to slow the velocity of the incoming feed.
My question is: are there any specific devices (other than a horizontal auger) that can be used to slow the velocity of the feed between the centrifuge and the dryer? Something specifically designed for the application of decelerating the feed from a centrifuge?
