SlideRuleEra
- Jun 2, 2003
- 5,527
I have taken on a potentially tricky project that three other engineers have withdrawn from. I would welcome discussion on the results to date.
The Client owns a 30 year old, two-story wood-framed, brick veneer residence. It is located within 75 yards of a tidal salt marsh creek. The house has experienced dramatic differential "movement" over its lifetime. Movement seems to be continuing today. For example:
1. The full-height brick chimney on the east side of the house has separated from the rest of the house and is leaning east.
2. A large covered screen porch on the south side has separated and is leaning south. A portion of the elevated wood-framed floor has buckled and heaved upward about 4 inches since I took on this project a couple of months ago. It has since "settled down", and is currently only about 1 inch high.
3. There are fresh cracks in the interior drywall,doors that no longer close, and floor irregularities throughout the house. There are numerous cracks in the brick work on all sides of the house.
To my surprise, none of the three previous engineers had any soil borings performed. So, I have had three slit-spoon samples taken at spaced locations around the house - per the Geotech's recommendations, one is 50 ft. deep, the other two are 20 feet deep. All three show essentially the same profile. Here is a rough description:
"N" values starting at 25 near the surface and decreasing to N = 4 at 8 feet below the surface. From 8 feet to about 28 feet "N" values were in the 1 to 4 range. The calcareous clay (locally called Cooper Marl) starts at 28 feet deep. This normally considered to be the significant bearing layer in the SC coastal regions.
The geotech report also says that the soils in the upper layers, from 2 feet deep to 8 feet deep are expansive clays.
The report does not identify an exact mechanism for the strange behavior of the house.
Could the combination of the upper expansive soils swelling and shrinking over time, combined with deeper very soft soils possibly allowing permanent settlement result in this continuing (and permanent) differential movement?
Other comments welcome, too.
![[idea] [idea] [idea]](/data/assets/smilies/idea.gif)
