Software
dik
25,837
Is there a free/inexpensive, relatively easy to use three dimensional FEM flow program that hydraulic structures can be modeled?
What 3D FEM programs are commonly used?
thanks, Dik
you might try the structural engineering forum for this. HEC-RAS is for hydraulic modeling, not structural FEM
cvg:
I was looking for hydraulic modelling, not stress analysis. Any suggestions?
thanks, Dik
2D programs are available for hydraulic analysis of drainage across land but is not very good for structures. See FLO-2D for an example and there are others. Most of the hydraulic theory for drainage structures is simplified for a 1-dimensional analysis and frankly 3D analysis would probably be overkill. HEC-RAS (River Analysis System) is good for rivers and channels including bridges and culverts. But most other types of structures are not handled particularly well with HEC-RAS. And HEC-RAS is 1D, ie: flow goes one direction only.
tsgrue - Excellent site but I don't see any 3D hydraulic modeling software on there - except for groundwater. I do see a couple of 2D or quasi 2D models.
Well, you're generally correct there. (I should have checked specifics before posting). GETM is listed and, obliquely, so is CCHE3D (NCCHE). For geomorphologic studies, you might consider the MD_SWMS (Multidimensional Surface-Water Modeling System) from USGS. I think you may actually be referring to what is commonly termed CFD (Computational Fluid Dynamics) rather than FEM (Finite Element Modeling). Check out " OpenFlower, OpenFOAM, Gerris Flow Solver, OpenFVM are examples of free CFD codes, but generally not with much more than a basic pre and post processor, if that. Fluent from ANSYS and FLOW-3D from Flow Science are two commonly used commercial codes. Some other ones are freely available from NASA and USACE (US citizens only, I think). But, this stuff is pretty complicated for the uninitiated. Most folks need graduate engineering mathematics and modeling coursework to successfully undertake CFD modeling work with these systems and - even then - the process can be quite time consuming. Beyond that, your simulation might simply be incorrect! CFD is not something that 99.999% of engineers would pursue (or need to pursue) - that's 1 in 100,000!
tsgrue: site engineering, stormwater
management, landscape design, ecosystem
rehabilitation, mathematical simulation
Thanks tsgrue, it could be CFD... I have used FEM to model strange stuff, and just assumed that water (as a continuum) could be modeled as such... I'm not up to speed with hydrodynamics. I'm looking at determining flow patterns around hydraulic structures (for my own interest and as part of a project (other skilled people will be doing the design))
Dik
