Dec 5, 2010 #1 ij39 Petroleum Nov 23, 2010 3 0 0 US I am looking for a software program that will help me space out a rod pump to reduce gas interference thank you
Dec 9, 2010 #2 cmlpetro Chemical Apr 1, 2005 64 0 0 CA Is this a vertical or horizontal well? If vertical, just run tubing so that pump intake is below the perforations. If the pump is already ran you can try installing a Baird valve on the tubing and hold some back-pressure. This can help with gassy pumping wells. Pentagon makes the Angel pump which they say will pump gas: http://www.24-7videotours.com/player/index.php?siteid=27&catid=78&movieid=429 Upvote 0 Downvote
