BAGW
- Jul 15, 2015
- 388
I have a question on solar panels mounting system on metal roof decks. Have anyone had experience with solar panel ballast mount on metal roof deck? Do the solar panels come with the steel framing and is the framing directly mounted on the roof? How is the wind uplift resisted? Will the framing be screwed to the deck?
Do anyone see a problem with attaching the solar panels directly to the roof with no ballast if the deck gets properly insulated?
