I want to use soldering to repair a leakage on a tubular stainless steel heat exchanger (347) and on an alunimun fin oil cooler (3003). Operating Temperature for both is approximately 400 degrees Farenheit. What would be the best soldering rod and flux to fix them, if there is any? Is there any AWS , mil standard or mil spec or SAE or ASTM document for soldering?
Thanks for your help!
