doomchemical
I have an assembly that has parts referenced to the top face of a large plate. I want to add a series of hole patterns for mounting components at 45 degrees to the other components. These may need to be moved later on. What is the best way to achieve this ? A Plane at 45 degrees to the orginal 1 ?
I appreciate any tips on this. Solid Edge V18 user
