thread712-461270
Hi Mykolaj/(or anyone experienced),
I was using 50% LDPE and 50% LDPE and optimized the air vacuum but still some bubbles get popped (or sucked in) on the forming roller in every meter of the film.
1) Is it because of the 50% and 50% ratio? As per your suggestion, if I use 70% LDPE and 30% LLDPE will this solve the problem? Do you have any explanation and experience of bubbles being popped while manufacturing? And how to solve this?
2) I found some of the bubble wrap films are very thin but very strong. It takes a lot of force to pop them. My resin supplier told me to use more LLDPE to make it stronger. Any idea or experience?
3) You said more LLDPE is not good because of shrinkage properties. But I found that LLDPE has a shrinkage range from 2.0 ~ 2.5 and LDPE has a more wider range of 2.0 ~ 4.5 Could you explain more about the shrinkage properties of LLDPE and how does it affect in the bubble wrap film?
marifca
marifca
