StrEng007
- Aug 22, 2014
- 506
Has anyone here had much luck with specifying a spray applied waterproofing membrane? More specifically, spraying directly to the cementitious material that is the walking surface?
I have a situation where it is too costly to get down to the waterproofing membrane of an exterior stair slab. Looking for solutions to try to use a spray applied finish to the existing system.
My only concern is creating a way that moisture gets locked in or a walking hazard.
