NPC5
Chemical
- Nov 24, 2008
- 15
I have a line coming off of a 300# spec line, a block valve, another block valve, and then the line returns to the 300# spec line. Between the two block valves there is a branch, a block valve (normally closed) and then the branch flows into a sewer header (150#) that feeds into an atmospheric tank. Why is it okay to have a 300#/150# spec break downstream of the block valve in the branch line? I have attached a drawing to try to clear my description up. Thanks.
