Speed of sound calculation 1
Harini Krishna
IN
I want to calculate the speed of sound in distill water
Containing
Chlorine : 4mg in 1L distill Water
Chloroamine : 4mg in 1L distill Water
Florides : 0.5mg in 1L distill Water
Copper : 0.005mg in 1L distill Water
Lead : 1.3 mg in 1L distill Water
Can you please help in this?
Thank you
Harini krishna
I can't see 10ppm of impurities affecting the speed of sound at all. Why do you think that it will?
P.E. Metallurgy
"calculate?"
I think you mean do a test to obtain....
The speed of sound in a material is the speed of a compression wave, which, in liquids and gasses, depends on the speed of the molecules. So, primarily, the mass of the molecules and the temperature.
Seems like a water quality test that will be massively affected by tiny temperature changes. This is what the mass spectrometer was designed for and won't work well for field measurements.
This tells you that you are barking up the wrong water column:
A change of 1 m/s out of 1560 m/s for a ONE PERCENT CHANGE in salinity, which means you're unlikely to see much of anything for concentrations that are 10,000 times smaller, assuming you could even measure speed of sound that accurately. You'd also need to spend a few years generating the calibration tables needed.
Is this really for work? I'm finding it increasingly difficult believe these are all plausible work-related questions, since you and your company have seemingly done NOTHING in the way of even basic internet searches.
TTFN (ta ta for now)
Odd's on it's a homework problem.
