1
- #1
zeroburn315
Aerospace
I have made an auger spiral as shown in the image below as a surface. After i use the unfold command, everything looks fine to me, However when I cut it and pull the flat part, to match the inside pipe dia, the pitch should come same as per my model, but its not the case. The pitch is higher compared to the folded (Original) model.
Then I did the manual calculations, and it shows the same unfolded dimensions as catia. which means the problem is not in catia, but I am not able to figure out the issue, if the unfolded part dimensions are correct, why is it not matching the dia of my model when i pull it to match the shape?
Am I missing something? can someone please help me regarding this issue?
