Split BOM 1
LesPaul82
CA
When a BOM becomes too long to fit vertically on a sheet, is there a way to seperate it into two?
Sean Nutley
Carmanah Design and Manufacturing
Vancouver, BC, Canada
When you insert a BOM, RMB it, and go into the Properties of the BOM. On the 3rd tab (Control) there is an option to select Split tables into multiple sections. You can also control the table height and direction.
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read faq731-376 to make the best use of Eng-Tips Forums?
Does this work for 2004? or is this for a previous version. I'm running 2004 and can't see the 'tab' you mentioned.
I can split the BOM by RMB on the BOM and selecting 'split'.....
Thanks.....
Phil
MadMango's post refers to the Excel based BOM.
[cheers] from (the City of) Barrie, Ontario.
[ponder] If you choke a smurf, [smurf] what color does it turn?
You can split the new BOM's too CBL.
1) Highlight a row or cell
2) RMB
3) Choose - Split\Horizontally above or below
Scott Baugh, CSWP [borg2]
faq731-376
Scott, I was responding to philatthehoff's question as to why he couldn't see the "control tab" when he RMB'd his BOM the way MadMango had described. MadMango's post was explaining how to split the Excel style based BOM in his reply ... but thanks anyway [thumbsup2]
