stennist
- Feb 26, 2021
- 5
I am looking for some advice on the use of split rings in the end grain of a timber member. I am designing a king post truss in which the top chords will bear against each side of the king post. I want to use 4" split rings to transfer the load between the chords and the king post. I understand how to calculate the strength of the split rings, but the code (NDS) is not very clear about edge distance, end distance, and spacing for these connectors in the end grain. The angle of cut to the grain in my particular truss is 63deg. Section 12.3.6 states to apply provisions for perpendicular to the grain loading for sloping surfaces with alpha between 45deg and 90deg. The top chords of my truss are 6x8 DF-L timbers and the split ring will be centered in the member. I know that my distance to the loaded and unloaded edges (at bottom and top of cut) is about 4.25". What I am not understanding is what my end distance is? Would this be the distance to the edge of the member(5.5in/2 = 2.75in)? Or is end distance ignored for this situation. Thanks in advance for the help and advice.
