Spot Welds 1
aardvarkdw
542
Where on a drawing do you attach the arrow head for a spot weld symbol? Any other weld you would attach it to an edge but with a spot weld there isn't an edge to attach to. If someone has an example that they can post I would appreciate it.
You can add a point.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
Most automotive manufacturers in Europe show a cross (X) in the true position with an attached note regarding the standard required.
ajack,
You wouldn't by any chance have a drawing you could post would you?
I've also used an "X" to locate spot welds (the same symbol used to locate datum points).
Here is a useful link I've posted before regarding weld symbols. Check Fig 3-8
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
