Spread pressure on slab
Batzo
IL
Hi (=
There is a way to assign spread pressure load on a model?
In the middle of the slab is the largest and on the end is less?
(that will be also dependent on time)
You can define spatially varying pressure using analytical field (expression or mapped). Time variation can be prescribed with amplitude.
