I am cycling the (wave)spring between its min and max operating length and after a certain no. of cycles(10k cycles) I pause it and perform a quasi-static load vs deflection test. Load vs deflection data is collected by fully unloading the spring and compressing to the minimum operating height (twice, ~10minutes). After that, the cyclic test is resumed. But when I resume I see a higher stiffness(load) at the minimum operating height. What could be the cause? does the spring recover some of the stiffness in that short break?
