springs
aeroheroes
New member
Mar 31, 2002
How to draw springs in autocad?, How to write a vlisp program in acad to draw a spring?
Look at this post
thread555-13480 link to the lisp file returns an error
use this link
Then under downloads click on code archive navigate to 1997
then select the month of October. this will have the code you need to create a spring. It's actually a heilicoil lisp
but basiclly the same thing
Good luck
[shadeshappy]
Try this one
It not mine, I got from By Scott Hull at CADALOG.
(defun C:SPIRAL (/ #ANG #ANG-DT #ANG-TAN #COILS
#DIA #LST #OSMODE #PITCH #PT #PT-0 #PT-1 #RAD
#RES #SEGS #TAN-0 #TAN-1 #Z #Z-DT #Z-END
#Z-TAN *error*)
(defun *error* (%A)
(if #OSMODE
(setvar "osmode" #OSMODE))
(cond
((= %A "Function cancelled") nil)
(t (princ (strcat "\nerror: " %A "\007\n"))))
(princ))
(if (not V:SPIRAL-DIA)
(setq V:SPIRAL-DIA 1.0))
(initget 6)
(setq #DIA (getreal
(strcat &quot;\nDiameter <&quot; (rtos V:SPIRAL-DIA) &quot;>: &quot;)))
(if (not #DIA)
(setq #DIA V:SPIRAL-DIA)
(setq V:SPIRAL-DIA #DIA))
(if (not V:SPIRAL-PITCH)
(setq V:SPIRAL-PITCH 0.25))
(initget 6)
(setq #PITCH (getreal
(strcat &quot;\nPitch <&quot; (rtos V:SPIRAL-PITCH) &quot;>: &quot;)))
(if (not #PITCH)
(setq #PITCH V:SPIRAL-PITCH)
(setq V:SPIRAL-PITCH #PITCH))
(if (not V:SPIRAL-COILS)
(setq V:SPIRAL-COILS 8))
(initget 6)
(setq #COILS (getint
(strcat &quot;\nNumber of coils <&quot; (itoa V:SPIRAL-COILS) &quot;>: &quot;)))
(if (not #COILS)
(setq #COILS V:SPIRAL-COILS)
(setq V:SPIRAL-COILS #COILS))
(initget 1)
(setq #PT-0 (getpoint &quot;\nCenterpoint: &quot;)
#RES 16
#RAD (* #DIA 0.5)
#ANG-DT (/ (* 2 pi) #RES)
#ANG 0.0
#SEGS (* #COILS #RES)
#Z-DT (/ #PITCH #RES)
#Z 0.0)
(repeat #SEGS
(setq #PT-1 (polar #PT-0 #ANG #RAD)
#PT-1 (list (car #PT-1)
(cadr #PT-1)
(+ (caddr #PT-1) #Z))
#LST (cons #PT-1 #LST)
#ANG (+ #ANG #ANG-DT)
#Z (+ #Z #Z-DT)))
(setq #LST (reverse #LST)
#ANG-TAN (/ pi 500)
#Z-TAN (* 0.001 #PITCH)
#TAN-0 (polar #PT-0 (- #ANG-TAN) #RAD)
#TAN-0 (list (car #TAN-0)
(cadr #TAN-0)
(- (caddr #TAN-0) #Z-TAN))
#Z-END (caddr (last #LST))
#TAN-1 (polar #PT-0 #ANG-TAN #RAD)
#TAN-1 (list (car #TAN-1)
(cadr #TAN-1)
(+ #Z-END #Z-TAN)))
(setq #OSMODE (getvar &quot;osmode&quot;))
(setvar &quot;osmode&quot; 0)
(setvar &quot;cmdecho&quot; 0)
(command &quot;_.spline&quot;)
(foreach #PT #LST (command #PT))
(command &quot;&quot; #TAN-0 #TAN-1)
(setvar &quot;osmode&quot; #OSMODE)
(princ))
Feel free to contact me I'm working on spirals. You can reach me at k281969@hotmail.com
but keep your post here for mutual benefits.
Pardal
