MEP.Learner
- Jul 22, 2016
- 26
Hi Engineers,
I have a situation where there is a shopping mall atrium with 25m ceiling height, atrium diameter is about 30m diameter on plan view.
So the question is what kind of sprinkler can be adopted for this atrium protection as in BS EN code mention that sprinkler more than 18m is not efficient.
Solution with Deluge sprinkler.
If deluge sprinkler / open head sprinkler to be used, what K factor and what type / what is the required spec of the sprinkler to be used.
Can normal OH3 5.6K factor (as per BS EN) can be used? Any concern that the water from this sprinkler not able to reach the fire source?
Any online reference or article that i can refer to design for this case?
My question does not specifically need to be in reference to NFPA. Any BS EN code/ LPC reference to solve this issue will help too.
Is there any fire related discussion topic other under than this sub forum “NFPA”?
Thanks.
