SPT Correlation to Pressuremeter deformation modulus and strength Reduction Factor
moe333
Geotechnical
Jul 31, 2003
416
Hi Guys,
The subject title says it all!
There is a project requirement for this information, and I have never worked with the Pressuremeter before.
Are the correlations (if they exist) very reliable?
Moe333 - have you referenced any of Paul Nayne's work?
Also you might contact Paul. He was a classmate of mine. He would likely send you inthe right direction while you wait on McCoy.
Most of the publications about pressuremeter are in french. Two books are quite interesting :
" Les essais in-situ en Mécanique des sols " by Maurice Cassan, Editions Eyrolles;1978. Vol 1 describes the different methods ( SPT, pressuremeter, CPT, etc )and corrélations between them and Vol 2 treats the design method associated to the various tests.
" The Pressuremeter and Foundation Engineering " by Baguelin, Jezequel and Shields, Trans Tech Publications,1978
From Cassan : N/(pl-p0) = 20 to 40 in clays, 30 in silts and 30 to 50 in sands (unit = MPa)
and N/Em =0.8 to 1.1 in clays, 3 in silts, and 2 to 6 in sands
don't forget Em is related to Young's modulus via the rheological factor 1/alpha
Menard proposed corrélations with CPT but not with SPT.
moe333
I didn't comment about reliability... Given the ranges you can assume it's not so good. In sands the correlation dépends on the angle of frtiction. If you have both parameters, I would say you are better off computing settlements with pressuremeter values. The only situation where it can be optimistic is in very soft clays where I personnally prefer to work with lab parameters.
BigH, that's one piece of equipment which is not used at all, pretty rarely anyway, in Italy. France as BigHarvey says is the main user in Europe.
I wonder what's exactly the cited strenght reduction factor, something related to the pressiometer or some general concept...
Thanks to all!
I need to spend some time looking at available literature.
Cheers!
moe333 my iPad was small print and my fingers accidently touched red flag which I wouldn't do. I hope I wasable to cancel. Dang nabit! [blush]
