solidworkswell
I am posed with a problem which i have no clue about. I am testing a gear transfer.
The gears are all Spur at pressure angle of 20°. The gear oscilates back and forth in its axial direction, now if it was radial, that would have made sense to me. The gear is enclosed in a housing. It is supported by a needle roller bearing and a ball bearing on both sides. It is
lubricated. The gear also has washers on either side between the bearing and gear.
Can someone tell me what would cause it do act in that manner.
