Do any of you know anyone who manufactures a 2:1 spur gearbox which can handle 8000NM?
I want to convert 90 degrees as output from an actuator to 180 degrees.
I understand that output will be reduced 50% by the ratio and probably a further 15% to 20% by inefficiency but believe that it would operate a 180 Choke Valve.
UK manufacturers preferred.
Thanks, Itascot.
Thanks, Itascot.
