SSR, EMR
Starwax
3
Hi
I’m trying to create a capacitor switching circuit using a bank of SSR's as the switching component. The signal is at 13.56Mhz. The problem I’m having is that the output capacitance of the SSR's is too high. There’s 8 of these devices in a row which when all turned off are creating a minimum capacitance of about 120pf. The spec is of course a lot lower so I’m assuming the frequency is causing the devices to have a higher output capacity? Would I be correct? I can get around the problem by replacing them with reed EMR's but ideally I would have SSR's as they are generally cheaper and would result in a smaller circuit. Is there any way to reduce the output capacitance or am I going to have to use EMR's to solve the solution?
You're trying to drive Solid State Relays (SSRs) at 13.56 MHz?
You're suggesting to use reed Electromechanical Relays (EMRs) at 13.56 MHz?
Sorry for the repeated posts...
Is the 13.56 MHz the 'switched' signal or the 'switching' signal?
My mistake. The 13.56 is the signal being switched. The switch itself is controlled by an external source so is operating at nowhere near that speed.
Okay.
13.56 MHz is "RF", and I don't recall seeing SSRs being used to switch RF. There are many technologies that can be used to switch RF, reed relays will work just fine carrying low power HF frequencies - if that's the approach that works best for your application.
Its driven by a micro controller. This I can set to whatever speed I need so isn't a problem, Its a automated tuning circuit for a HF RFID antenna and the response isn't that crucial. Im not an RF engineer so this is a new area to me, after a bit of reading online I came to the conclusion (though apparently a wrong one) that SSR's were normally used,this would have also been beneficial for my space concerns and reducing the EMF (opto-coupled). However yesterday after starting this post I found this:
Which I think will probibly do exactly the same thing. The circuit is low power so should be fine and I can reduce the EMF in other ways.
Cheers for your help anyway
