morkman
- Sep 6, 2012
- 2
Good afternoon everyone. I am having trouble with a 303 sst machined component where the hardness of a material is called out on the print as ASTM-A582 condition A. Unfortunately there is only a maximum hardness 282 Brinell scale specified. Does this mean that the supplier can produce any hardness of material as long as they are under the 282 Brinell scale?
I performed a micro hardness test on some components and found that batch A consistently produced around 60 RA and batch B produced in the low 50's RA. One of the components from batch B produced harnesses of 57 RA and 51 RA when tested at different surfaces. Is this normal to see that great of a variation from the same piece of metal.
Also is 55 RA compared to 60 RA a significant decrease in hardness or something that I should be concerned about?
Any insight would be appreciated.
