ST vs RST
mTreadwell
6
Can anyone tell me the difference between ST and RST designations from DIN 17100? We're supplying replacement parts based on an old drawing from a European manufacturer and this is a new one for me. I'm specifically interested in RST 52-3; I have a crossover chart that shows some RSTs as similar but higher grade than their ST equivalent, but this one isn't listed. Thanks in advance!
The meaning of 'R' was: Rimmed Steel (= steel containing iron oxide to give a continuous evolution of carbon monoxide while the ingot is solidifying) is NOT permitted.
Sorry Shmulik, but I think it was just the opposite or I misundertand the meaning of rimmed. R meant killed. S 355 JR2 should now be the equivalent to RSt 52-3.
It sounds like you two are saying the same thing (that is, micalbrch misunderstands rimmed as he suggested - or missed the "NOT permitted" at the end of Shmulik's post). Rimmed = CO bubbles allowed to form during cooling. Killed = aluminum or silicon added to capture the oxygen coming out of solution. So despite the non-matching initial, R=killed/not rimmed.
Thanks for the insight guys!
